[e30] Keiciam m40 i m42, reikia pagalbos
Re: [e30] Keiciam m40 i m42, reikia pagalbos
m42 radijatorius yra didesnis negu m40.
ismatavimus tuos pacius duoda, tiek su kondyske, tiek be. realiai kiek maciau visu keturcilindriu e36 vienodi isskyrus tds.
mano m42 su m40 radiatorium laiko identiska temperatura pries tai buvusiam m40.
cia as kalbu apie e30.
- mindaugas666
- BMW: BMW E30sed b18, E30coup b18, E32 m30b30
Sveiki. Man iskilo toks klausimas jeigu ant m42 uzdedi m40 smagrati ar tiks starteris sankaba ir diskatorius nuo m42?
1990m. E30 318 - LPG (-M40B18) + Virintoze 2/3 drift project 60%
1987m. E30 318 + LPG + Virintoze 4/5 project 2%
1990m. E30 318i lpg touring darbinis arkliukas
1997m. E39 525i daily
1987m. E32 730 ex
http://www.facebook.com/BornToGoLow
varikio m40b18 dalis
1987m. E32 730 ex
e36'tam tinka, turetu ir e30 tikt
Jei kartais kyltu problemu del laidu atrinkimo:
- babinos.jpg (103.92 KiB) Viewed 2776 times
- laidai.jpg (96.25 KiB) Viewed 2776 times
- BMW: E30 m42, E36 m43b16
[/quote]Fanatic wrote:tai vat ponios ir ponai, iskilmingai galiu pasakyti, jog uzsungus laidus taip:
C101 - Function - X20
1 - Alternator - 25
2 - Oil Level (static) - 1
3 - Not Used
4 - Coolant Temp (gauge) - 12
5 - Oil Pressure Switch - 23
6 - 12v feed for diagnostic plug - 22
7 - Ignition (switched) - 21
8 - Fuel Economy - 24
9 - Engine Speed (tach) - 20
10 - Oil Level (dynamic) - 2
11 - SI Reset - 7
12 - CEL - 8
13 - Fuel Pump Relay - 13
14 - Speed Signal - 14
15 - Starter (unloader relay) - 15
16 - Diagnostic Plug - 19
17 - Not Used
18 - Voltage during start - 18
19 - Not Used
20 - ABS - 3
susitvarke ir ABS ir ekonomaizeris, beliko temperaturini pasikeisti ir viskas bus lyyyyyyyyyyyyyygis![]()
o ka del ekonomaizerio darei? Ar cia prie to pacio jungimo viskas pasidare?
Klaida sitos pavodkes jungime:
11 - SI Reset - 7
turetu buti:
11 - SI Reset - 19
Gal ne visiem, bet as uzsiroviau.Puse dienos ieskojau priezasties, del ko nesiveda.Po to jungaiau is paveiksliuko auksciau.Auto E30 m40b16 keiciau i M42b18 94.07.
- Karolis316
- BMW: E30 316i
[E30] M42B18 tepalo lygis e30 kebule
Dedant m42 m44 varikli i e30 kebula su e30 m40 karteriu reiktu pasikeisti ir matuokle (e30 m42 ji kitokia jei m40) arba pilti kazkur 2,2 2,3 cm virs m40 max ribos.
Sekmes visiems
Sekmes visiems
- P1610652.JPG (119.86 KiB) Viewed 113 times
