[e36] m52b28 ECU remap
unius
BMW: e36 328
Post by unius » Fri Jun 05, 2015 1:42 am
Hi,
ka manot apie toki moda: http://www.ebay.com/itm/BMW-Complete-Ch ... 1f&vxp=mtr
For maximum performance of 270 Hp/355 Nm, use this Ecu for stock or track car using or not additional equipment:
- using ecu on stock m52b28 it gains 213hp ( stock 193hp )
- using with m50b25 or Schrick intake manifold + Cold air intake kit, it gains 231hp
- using with m50b25 or Schrick intake manifold + M3 EU headers / Supersprint headers and M3 US camshafts you get 247hp
- If using more aggressive Performance camshafts like recommended Dbilas, Catcams, Schrick, BavarianSolution with at least 264 degrees and higher + valve lift not less than 10.5 mm, you get 265-270 Hp and 329-355 Nm of torque.
kokiu budu jie ten remapina tuos kompus? Lytuoja cipa ar tiesiog kazkokiu budu programa editna?
Labai jau graziai skamba: remapintas kompas + m50b25 isiurbimas = ~38AG prieaugis uz tokia kaina tai juokinga
Ausvis528
BMW: E60 530i 190kw,E39 535i 180kw
Re: [e36] m52b28 ECU remap
Post by Ausvis528 » Fri Jun 05, 2015 5:21 pm
samis_p
Post by samis_p » Sun Jun 07, 2015 8:53 pm
Kate maise. Jei taip butu lengva padaryt 240ag is 2.8, tai niekas hibridu nedarytu. Buvo m50b28 hibridas pardavime jei neklistu, su veleneliais keistais, darytu kolektorium ir dar daug modu, paleistas ant e85 ir VEMS - 250ag ar 270ag. Kazkas tokio. Tai tikrai labai labai labai abejoju, kad vien is ECU remapo sitiek galios susikels. Remapo tikslas yra padaryt mapa butent TAM varikliui. Tokie cipai, sumapinti ant kito variklio - laiko gaisimas.
Simas323
BMW: E36/5 323Ti M52B30
Post by Simas323 » Mon Jun 08, 2015 2:14 pm
Ir kam aš švaisčiau pinigus perprogramavimui, reikėjo tiesiog šitą parsisiųsti :D :D
Post by zygasbmw » Mon Jun 08, 2015 4:28 pm
cia tas pats,kas sport filtras +5 ag :)
Gedass
Post by Gedass » Tue Jun 09, 2015 9:49 pm
samis_p wrote:Kate maise. Jei taip butu lengva padaryt 240ag is 2.8, tai niekas hibridu nedarytu. Buvo m50b28 hibridas pardavime jei neklistu, su veleneliais keistais, darytu kolektorium ir dar daug modu, paleistas ant e85 ir VEMS - 250ag ar 270ag. Kazkas tokio. Tai tikrai labai labai labai abejoju, kad vien is ECU remapo sitiek galios susikels. Remapo tikslas yra padaryt mapa butent TAM varikliui. Tokie cipai, sumapinti ant kito variklio - laiko gaisimas.
Nieks ir neraso ten, kad is stock bus, is stock tipo 213Ag :)
fipa
BMW: E36 318iS
Post by fipa » Tue Jun 09, 2015 10:27 pm
Gedass wrote: Nieks ir neraso ten, kad is stock bus, is stock tipo 213Ag :)
Klausimas ar išvis bus bent jau org. arkliai?
GedasK
Post by GedasK » Wed Jun 10, 2015 4:22 pm
Tai kad pardavus 2.8 ir dasimetus sito ECU kaina iseina 3l plyta. Bent jau as taip daryciau :)
unius
BMW: e36 328
Post by unius » Thu Jun 11, 2015 3:45 pm
GedasK wrote:Tai kad pardavus 2.8 ir dasimetus sito ECU kaina iseina 3l plyta. Bent jau as taip daryciau :)
na jeigu tai isimt/idet, surast kam-parduot/kur-nupirkt nieko nekainuoja tai tada :appl
Anyway, kompa atitinkama jau turiu, manau pribresiu sitam dalykui anksciau ar veliau. Nera tokia dideli pinigai...
Bet reikes butinai ant stendo prasukti pries irpo.
Gal kas rekomenduos kur galima Vilniuje ant dyno prasisukti nebrangiai? :alio
zladzejus
BMW: e36/5 323ti
Post by zladzejus » Tue Mar 15, 2016 10:42 am
ir m52b25, ir m52b28 uzdejus m50 kolektoriu ir su chipu galima isgauti iki 210ag su b25 ir iki 230ag su b28. :)
Jeigu ka domina toks remapas, kreipkites pm.
Zeus999
BMW: e36 328i
Post by Zeus999 » Fri Oct 21, 2016 10:37 am
Gal kas parekomenduotų kur gerai ant stendo Vilniuje atliktų remap? Gal kas darės, atsiliepimai, kainos? Viskas domina :)
M52B28, M54B30 įsiurbimo velenas, M50B25 įsiurbimo velenas ant išmetimo, M50B25 įsiurbimo kolikas, M50 išmetimo kolikai, išmetimas >60mm.
Dėkui
robertass
Post by robertass » Sat Oct 22, 2016 9:28 pm
Zeus999 wrote:Gal kas parekomenduotų kur gerai ant stendo Vilniuje atliktų remap? Gal kas darės, atsiliepimai, kainos? Viskas domina :)
Dėkui
parasyk atsiliepima jeigu padarysi :)
Adrenal1n
BMW: E36 323
Post by Adrenal1n » Sat Oct 22, 2016 10:34 pm
Siaip insane daro tai :) pats zadu kreiptis i juos. Arba klaipedoje laimis yra..o toks klausimas kodel sudinesnius ismetimo kolikus uzdejai, ir panaikinai gera dvieju vamzdziu ismetima?
Zeus999
BMW: e36 328i
Post by Zeus999 » Mon Oct 24, 2016 12:54 pm
Kad kaiptik smagesni :)
http://www.bimmerboard.com/members/shay ... 205740.jpg
O aplamai swap'intas variklis, tad išmetimo nebuvo :)
slimshady
BMW: E46 328 coupe
Post by slimshady » Mon Oct 24, 2016 2:31 pm
Dėkui
Po truputį domiuosi M52tub28 variklio tobulinimu ir pasistojo klausimas kodėl naudojai įsiurbimo koliką M50B25, o ne M54B30 ar M54B25? Užsienio forumuose pagrinde randu Info, kad naudoja pastaruosius du su adapteriu M52 variklio droselinei sklendei. Gal M50B25 koliko montavimas ant mano variklio paprastesnis būtų, t.y. be droselinės sklendės adapterio? Taip pat randu Info, kad M52tub28 varikliui naudojami įsiurbimo ir išmetimo velenai nuo S52B32 variklio. Bet spėju, kad tai deficitinės dalys ir brangios... Ar tavo pasirinkti velenai yra alternatyva mano paminėtiems?
P.S. Beje gal kas esate realiai susidūrę su M52B30 strokerio modifikacija?
"There is another alternative to turn your engine into 3-liter M52B30. You need to purchase M54B30 crankshaft to implement this project. Standard pistons should be milled down to 1.6 mm. The rest of bearings should be left stock. M50B25 intake manifold is recommended for improvement of HP characteristics."
Spėju, kad čia jau gan brangus ir sudėtingas reikalas būtų....
P.S.p.s. ar aš čia iš viso supainiojau E36 2.8 variklį su E46 2.8 ? :V
slimshady
BMW: E46 328 coupe
Post by slimshady » Mon Oct 24, 2016 2:42 pm
Sorry tikrai suklydau :P
M52tub28 tobulinimo planas jei kam aktualu:
The M50 manifold, as previously mentioned, will not fit on the M52TUB28 (the M52 2.8 litre engine in the E46 and later E38 and E39 models) due to the dual VANOS as it won't clear it. This engine has a different style of engine cover which is the easiest way to differentiate between the two engines.
M52B28 engine (which WILL accept M50 inlet mani):
http://aboutbmw.net/uploads/posts/2009- ... 1500_1.jpg
M52TUB28 engine (which WILL NOT accept M50 inlet mani):
ImageShack® - Online Photo and Video Hosting
It's worth noting that, with the M50 manifold, ensure it is from a 325i or 525i. Any other type of M50 manifold, such as the one from the 320i 520i or the M52 inlet manifold from the 323i and 523i will not yield any, or any significant, gains. Also people do include Big Bore Throttle Bodies for a little extra flow. This is a MACHINED OUT 325i or 525i throttle body where the inside has been enlarged. A standard one IS NOT a 'big bore', despite many misconceptions.
Keep this in mind when shopping.
So this brings us to the M52TUB28 engine. There IS a solution. And it's not as widely known as the M50 manifold so, if you're sneaky, you can probably get everything you need for around £100 (£60 for the inlet manifold and around £40 for the adaptor plate).
You fit the M54B25 inlet manifold or the M54B30 inlet manifold, that is the manifold from the later (2001 onwards, check the engine number if you are not sure) 325i or 330i. Note that I have not heard of anyone fitting the M54B30 (330i) inlet manifold to their car successfully, but they say it is possible.
To attach this M54B25/M54B30 inlet manifold to your car, you will need an adaptor plate located here:
zroadster.net • View topic - M54 intake manifold to M52TU - ADAPTERS
There are stories of people having to attach it all together with just two bolts, however people who have done this have successfully run this without issue for years, so it's safe to say that is secure enough. if in doubt, make up some small brackets with nuts, bolts and square washers to hold it all together.
The gains you make are as follows:
193bhp -> 213bhp (+20hp gain) 328i
170bhp -> 190bhp (+20hp gain) 323i
The torque curve, like on the earlier engines, is shifted up 500RPM so expect to rev a little more. Alternatively get your engine remapped to have a small boost in torque and further boost in power. The maximum power you can economically expect to have out of your M52TUB28 is approx 225bhp and 205bhp from the M52TUB25.
As always, remove the battery positive terminal for 15+ minutes after performing this mod to reset the DME and engine sensors, your engine will then be reset at default values and will 'map' itself in ways.
Good luck!
Zeus999
BMW: e36 328i
Post by Zeus999 » Mon Oct 24, 2016 3:53 pm
Sveikas,
Taip, tai skirtingi varikliai, kolektorių angos skiriasi, M54 D - formos, M52/50 O - ovalo.
Taip, pasirinkti velenai biudžetinis variantas.
Tavo atvėju galima dėti M54B30 įsiurbimo kolektorių, bei įsiurbimo veleną, nesu tikras, gal teoriškai būtų galima pamodifikavus ir antrą įsiurbimo veleną ant išmetimo pusės uždėti :) Gal atsiras kas protingesnis paprotins kas jau daręs kažką panašaus.
Sėkmės
Simas323
Post by Simas323 » Mon Oct 24, 2016 4:44 pm
apie b30 strokeri rašiau ir daug diskutuota buvo apie visas modifikacijas keliose temose žemiau. Tema apie kolikus išmetimo ir kita apie modifikacijas ;)
slimshady
BMW: E46 328 coupe
Post by slimshady » Mon Oct 24, 2016 5:05 pm
Zeus999 wrote:Sveikas,
Sėkmės
Tai manau man kuo puikiausiai sueitų ir M54B25 įsiurbimo kolektorius, nes jo kanalų forma ir plotis identiškas M54B30. Plius dažnesnis variklis ant ardymo pardavime būna. O dėl velenų tada reikia dar pasidomėti nuo ko geriausiai tiktų.
http://www.google.lt/search?q=m52tub28+ ... TfH4cDM%3A
Simas323 wrote:apie b30 strokeri rašiau ir daug diskutuota buvo apie visas modifikacijas keliose temose žemiau. Tema apie kolikus išmetimo ir kita apie modifikacijas ;)
Einu ieškoti ir skaityti ;)
