[E30] M50B25 variklio dejimas
- Mindaugazz
- BMW: A4; ZX6R e46 320
ydomiai cia su tuo nuorinimu kazkaip visiems, man ir m40 ir m50 abu buvo su termostatais, tiesiog pripili, uzkuri, slangas pamaigai vel dapili ir viskas nusiorindavo
na bus matyt dabar tik renku info reikia pirma kebulas prikelt kad butu verta plyta det
Hey guys!
My name is M. Golubovičs from Latvia and i am drifter. I'm drifting with e30 M50b28 and also i participated in some rounds of Lithuania drift championship.
So story short - i want to improve my engine, no V8 or turbo because new tires cost and i'm driving with old tires with some rubber left...
I'm looking for sport camshafts, schrick costs some money, but i heard from some my buddys who are racing with audi and VW in rally, that they have sport camshafts from Lithuania, Kaunas.
Maybe someone knows what i am talking about and give me some contacts to that place
Thanks and hope to see you in Kaunas 11.05.2013, in first round of D1sport event;)
- BMW: E30 318is, E36 318is
Hi M., you can try http://autotechnika.lt/mixs87LV wrote:Hey guys!
Vel susiduriau su problema.Variklio elektroje atsiziurejau(paveluotai)kad yra nupjautas laidas tiksliau 4.Kai bandau kurti be ju, neuzmaitina man Kuro siurblio laido is variklio elektros, pabandziau juos visus duot i +, siurlys pradeda veikt bet atvirksciai-isjungus degima, ir neatidarineja purkstuku,Gal galit kas ka patarti?
va cia matosi geriau
- greengoo115
is kokio kebulo variklis su pravotke?
Is 1992 E36greengoo115 wrote:is kokio kebulo variklis su pravotke?
sveiki,
dedu M52B28 su EWS3. variklis isimtas is e39 automato. beda kad nesuka starteris. ant ews yra melynas laidas einantis i greiciu deze per kuri kompas turi suprast kad ijungta P arba N pozicija ir tik tada leidzia kurt varikli. klausimas ka reikia paduoti i ta laida? Kiek radau internete tai High signal leidzia kurt low signal ne. ar high signal +12v? bijau ka nors sudegint, gal kas jau susidure?
kazkodel atrodo kad ten turejo but rele.galiu klystVoodoo wrote:Vel susiduriau su problema.Variklio elektroje atsiziurejau(paveluotai)kad yra nupjautas laidas tiksliau 4.Kai bandau kurti be ju, neuzmaitina man Kuro siurblio laido is variklio elektros, pabandziau juos visus duot i +, siurlys pradeda veikt bet atvirksciai-isjungus degima, ir neatidarineja purkstuku,Gal galit kas ka patarti?
auto remonto darbai,varikliu keitimas,varikliu pritaikymas i kita kebula(BMW automobiliams),deziu,sankabu keitimas,sankabu ir smagraciu pritaikymas,hidrauliniu rankiniu montavimas,stabdziu upgreidai ir t.t. 864712706,Mazeikiai
https://www.facebook.com/RokoGarazas?ref=ts&fref=ts
As kai ziurejau autodatoj, tai irgi prie tokios isvados priejau, bet konkreciau nieko neissiaiskinau.Tikriausiai teks elektros ieskotis kitos ar dar ka daryt.Rokyz wrote:kazkodel atrodo kad ten turejo but rele.galiu klystVoodoo wrote:Vel susiduriau su problema.Variklio elektroje atsiziurejau(paveluotai)kad yra nupjautas laidas tiksliau 4.Kai bandau kurti be ju, neuzmaitina man Kuro siurblio laido is variklio elektros, pabandziau juos visus duot i +, siurlys pradeda veikt bet atvirksciai-isjungus degima, ir neatidarineja purkstuku,Gal galit kas ka patarti?
PAU wrote:sveiki,
Jei kam bus aktualu reikia paduoti +12 nuo degimo i melyna/juodu laida.
- VartotojoVardas
- BMW: e30 2doors dyzel
pas m54 nerasta kuro abratkes.
pagal bmwfan schemas nesimato, kad tokia apskritai egzistuoja.
ka daryti?:D
siuo metu turiu standartini isorini e30 m40 siurbliuka, bet nenumanau kuom baigsis ji aklai pajungus. gal zinote, kokio slegio reikalauja m54 purkstukai? butu galima statyti trisaki su voztuvu atgal i baka, kad palaikyti reikiama slegi... ar galima tiesiog pumpuoti kiek siurblys pajegs?
dar toks dalykas apie elektronini gazo pedala. ar tinka pedalas nuo m21 elektroninio siurblio? ar ten jau turi buti butent nuo m54?
dar prie to pacio. jei priburti sklendes valdyma troseliu. viskas veiks kaip turi buti?
ka daryti?:D
su trosu neveiks. iskur pas e30 m40 isorinis siurblys? buvo tik vidinis.abratke turi buti.beto koks butent m54? 3l? nes pas 3l kuro filtras eina kartu su slegio reguliatoriumi.
- VartotojoVardas
pas mane nuo pirkimo buvo isorinis siurblys. bake tik plude buvo.
motoras m54b25
na, del abratkes dar reiks pasidometi, bet bmwfan.info ir uzsienio forumai rodo, kad pas mano motora "fuel rail"(nemoku lietuvisko atitikmens) yra akla. t.y. tik su viena jungtimi:/
butu idomu suzinoti ka nors tiksliau apie ta elektronine sklende. ji valdome per kompiuteri ar tiesiai nuo pedalo?
apziurejes motora(per salta buvo krapstytis, tai tik is vaizdo) nesugebejau atsekti kurie laidai valdo sklende, bet manau, kad sita fyske yra butent nuo sklendes:
http://oi48.tinypic.com/js2jk7.jpg
pataisykit jei klistu
motoras m54b25
fuel rail -yra kuro takelis.
atsiprasau uz kvailus klausimus:
1. klausimas: dabar plytos starterio komandinis laidas kur prisisuka M6 verzle, turi but 2 laidai ar 1, nes pas mane yra juodas su geltonu bruksniuku prisuktas ir dar nulausta kilpute juodas su zaliu bruksniuku, ar jie abu ten jungiasi, nes kazkaip nera arti jokio kito daikto kuri reikia pajungt. noreciau tokius palaidus laibukus susijungt kol variklis ant grindu garaze, o ne kai sukamsytas i e30 kebula.
2. klausimas: kuria matuokle det, nes kai dedu pitako matuokle ji man kliuna kolektoriaus, ar det kregzdes nes ji ten dailiau isipaiso, tik kaip su alyvos kiekiu karteryjke td. nes pitako karteris ciuciut mazesnis vizualiai ir matuokle ilgesne (giliau isikisa nei kregzdes).
1. M6 - juodas/geltonas, M5 - juodas/zalias
2. Kaip gali pitako matuokle neisideti, jeigu karteris pitako, o kolektoriai vienodi?
1. tikrai taip, priesais M6 kontakta, net likes ziedelis matosi, anksciau kazkip net nesimate kol idemiai nepasiziuri
2. tai gal nepitako, man tik sake kad pitakoto, o kliuna kad mazai sulenkta, negaliu istatyt riebokslio kad nelystu i lauka tepalas. nebent megint stipriau sulenkt ja atsargiai, kad nekluptu vamzdelis?
va virsuje pitako (nezinau ar tikrai) apacioje kregzdes matuokle ir vamzdukas. kregzdes patik matuokle trumpesne (galas pats nulaustas, bet neesme, min riba dar yra), o tariama pitako ilgense ar nebus varikliui tepalo maza? arba supilt pagal kataloga tada uzsizymet savo mietke max ir min primest zemiau?
As tai dejau ta apatine kur nuotraukoje, pasukinejau pasukinejau ir tilpo.tadux wrote:1. tikrai taip, priesais M6 kontakta, net likes ziedelis matosi, anksciau kazkip net nesimate kol idemiai nepasiziuri
tai apatine yra kregzdines nes pas mane is kregzdes sawapas imtas. tai vat man ir ji dailiau atrodo graziau ziurisi. tik kaip su tepalo lygiu?
