[E30] M50B25 variklio dejimas
marukasBMW
BMW: E39
Post by marukasBMW » 09 Nov 2006 22:32
The standard E30-radiator...maybe I'm going to change it...
yes, but my e30 is(was) 316i :D
rychkaBMW
BMW Fan draugas
BMW: e30 325iC M tech1
Post by rychkaBMW » 10 Nov 2006 00:33
o pas mane plytos radiatorius idetas
e30 325iC M Tech1
E36/5 318Ti individual M spor
marukasBMW
BMW: E39
Post by marukasBMW » 11 Nov 2006 09:16
kregzdes ar pitako? turiu pitako bet ikist nerealu yra
rychkaBMW
BMW Fan draugas
Post by rychkaBMW » 11 Nov 2006 12:40
pitako
e30 325iC M Tech1
marukasBMW
BMW: E39
Post by marukasBMW » 12 Nov 2006 04:47
gal kitoks nes mano tarp lonzeronu kokiais 5cm platesnis.
marukasBMW
BMW: E39
Post by marukasBMW » 20 Nov 2006 08:37
palikau m40 radiatoriu,kol kas uztenka.
Beje neveikia ABS, ten ta laida nuo stekerio 14 blge kur prijungt?
marukasBMW
BMW: E39
Post by marukasBMW » 23 Nov 2006 18:18
tai ar niekas neturi ABS'u e30 m50?
Pawlaz
BMW: E30 340i M-techII
Post by Pawlaz » 23 Nov 2006 18:19
pas mane su abs bet viskas gerai veikia..
http://www.veld.lt
ADD929
Post by ADD929 » 23 Nov 2006 22:57
Klausimelis: ar kas sukot ant stendo savo M50 po to kai ykisot i e30?
marukasBMW
BMW: E39
Post by marukasBMW » 24 Nov 2006 18:51
kai keiti stekeri lieka abs laidas 14nr, tik nzn kur ji prijungt?
Pawlaz
Post by Pawlaz » 24 Nov 2006 19:18
su 16 arba 17
http://www.veld.lt
marukasBMW
BMW: E39
Post by marukasBMW » 24 Nov 2006 21:08
nu jo, taip rasoma e30.de ir 16 17 eina tiesiai i diagnostikos stekeri,jung nejung nepades. Bent pas mane taip.
rychkaBMW
BMW Fan draugas
Post by rychkaBMW » 25 Nov 2006 01:33
izher wrote:kai keiti stekeri lieka abs laidas 14nr, tik nzn kur ji prijungt?
na va butent kad jauciu niekas visai butu idomu prasukt o tu add gal sukai???
e30 325iC M Tech1
53kW
BMW: e30
Post by 53kW » 28 Nov 2006 20:57
gal galetumet parasyt kiek mazdaug jum kainavo m50b25 komplektas y e30. kiek kas mokejot. kad zinot kiek moket butu galima.
dar vienas klausimas, kaip yra jei su vanosu? su pajungimu pravodkes nebus bedu? kaip suprantu imamas kompas nuo m50b25 su visa pravodke ir grudamas y e30. jei su vanosu, ar nebus ten kokiu navarotu papildomu? nelabai suprantu kaip jis ten veikia, tik zinau kad velenelio fazes keiciasi.
kaip su oro filtro deze? ar tinka nuo e34? nuo kokios geriausia det?
e30
Pawlaz
Post by Pawlaz » 28 Nov 2006 21:51
na as trumpai:
variklis m50b25 be vanos - 1100lt
variklio ausys nuo e36 - 40lt
e36 duslintuvo kelnes ir ismetimo kolektorius - 30lt
variklio pagalves e34 2vnt - 20lt
e36 radiatorius - 150lt
elektrinis ventiliatorius - 20lt
greiciu dezes flansas nuo e36 m40 greiciu dezes 10lt
benzo ir ausinimo slangos 25lt
cia isvardinau ko uzteko, kad ikisti ir uzkurti plius tepalai, filtras, dirzas, ir kitos smulkemos, oro filtra kugini dejau nes netilpo deze..
http://www.veld.lt
MariusE30
Post by MariusE30 » 28 Nov 2006 23:26
Pawlaz wrote:isvardinau kiek as mokejau kai kurios detales rinkoje kainuoja gerokai brangiau..
Vistiek ačiū, nes dbr jau aiškiau kas ir kiek gali kanuoti ;) O kaip efektas? nzd Patenkintas rezultatu ar nelabai?
Pawlaz
Post by Pawlaz » 28 Nov 2006 23:36
na kai mano bmw buvo su m20b20 varikliu tj jau butinai reikejo pakeist i teisingesni :) normaliai db reiktu dar chip'a isidet..
http://www.veld.lt
53kW
BMW: e30
Post by 53kW » 29 Nov 2006 00:04
[quote="Pawlaz"]na as trumpai:
kompas? pravodke yeina y sita kaina? kaip su generatorium? kuro siurblys? vairo stiprintuvas? ar kas nors tinka nuo m20? ar cia viskas yeina y ta kaina kad grynai isimta is masinos, ir niekas nenurinkta nuo to variklio.
greiciu deze ir yeina?
e30
Post by zygasbmw » 29 Nov 2006 00:15
cia turetu but su deze ir kompu.vairo stiprintuvas lieka nuo e30 viskas ten tinka
53kW
BMW: e30
Post by 53kW » 29 Nov 2006 00:22
pas mane vairo stiprintuvo isvis niekad nebuvo, bet prie progos reiktu ysidet.
dekui uz info.
e30
