Page 8 of 8
Re: [e30] Keiciam m40 i m42, reikia pagalbos
Posted: 04 Apr 2011 17:37
by zygasbmw
m42 radijatorius yra didesnis negu m40.
Posted: 08 Apr 2011 12:41
by Topazas
ismatavimus tuos pacius duoda, tiek su kondyske, tiek be. realiai kiek maciau visu keturcilindriu e36 vienodi isskyrus tds.
mano m42 su m40 radiatorium laiko identiska temperatura pries tai buvusiam m40.
Posted: 08 Apr 2011 18:31
by zygasbmw
cia as kalbu apie e30.
Posted: 06 Oct 2011 12:02
by mindaugas666
Sveiki. Man iskilo toks klausimas jeigu ant m42 uzdedi m40 smagrati ar tiks starteris sankaba ir diskatorius nuo m42?
Posted: 06 Oct 2011 14:29
by Topazas
e36'tam tinka, turetu ir e30 tikt
Posted: 11 Apr 2012 10:13
by Tadela
Jei kartais kyltu problemu del laidu atrinkimo:
Posted: 21 Apr 2012 22:23
by Antanas00
Fanatic wrote:tai vat ponios ir ponai, iskilmingai galiu pasakyti, jog uzsungus laidus taip:
C101 - Function - X20
1 - Alternator - 25
2 - Oil Level (static) - 1
3 - Not Used
4 - Coolant Temp (gauge) - 12
5 - Oil Pressure Switch - 23
6 - 12v feed for diagnostic plug - 22
7 - Ignition (switched) - 21
8 - Fuel Economy - 24
9 - Engine Speed (tach) - 20
10 - Oil Level (dynamic) - 2
11 - SI Reset - 7
12 - CEL - 8
13 - Fuel Pump Relay - 13
14 - Speed Signal - 14
15 - Starter (unloader relay) - 15
16 - Diagnostic Plug - 19
17 - Not Used
18 - Voltage during start - 18
19 - Not Used
20 - ABS - 3
susitvarke ir ABS ir ekonomaizeris, beliko temperaturini pasikeisti ir viskas bus lyyyyyyyyyyyyyygis
[/quote]
o ka del ekonomaizerio darei? Ar cia prie to pacio jungimo viskas pasidare?
[/quote]
Klaida sitos pavodkes jungime:
11 - SI Reset - 7
turetu buti:
11 - SI Reset - 19
Gal ne visiem, bet as uzsiroviau.Puse dienos ieskojau priezasties, del ko nesiveda.Po to jungaiau is paveiksliuko auksciau.Auto E30 m40b16 keiciau i M42b18 94.07.
[E30] M42B18 tepalo lygis e30 kebule
Posted: 13 Jan 2021 01:45
by Karolis316
Dedant m42 m44 varikli i e30 kebula su e30 m40 karteriu reiktu pasikeisti ir matuokle (e30 m42 ji kitokia jei m40) arba pilti kazkur 2,2 2,3 cm virs m40 max ribos.
Kodas 1734248 (e30 m42)
Sekmes visiems
Posted: 02 Feb 2021 01:01
by tadux
dedi viska nuo m40 nes karteris nuo m40. idesi ilgesne matuokle tai max norma rodys o is tikruju bus maziau. pas mane pati ant m42b18 uzdetas marteris ir viskas nuo m40, 4metai dar neuzlinko variklis
Posted: 02 Feb 2021 04:10
by _marshall_
Man irgi tai naujiena, bet įtariu, kad Karolis teisus. Pagal kataloga i m42 pilasi daugiau tepalo nei m40 ir matuokliu vamzdeliai vienodu kodu, o pačios matuokles skirtingu. Tikriausiai nebereikalo.
Paziurek cia:
M40:
http://bmwfans.info/parts-catalog/E30-2 ... _dipstick/
M42:
Posted: 02 Feb 2021 23:21
by tadux
na gerai kad laikiau max norma. Reiks db itrupinti tepalo dar
Posted: 24 Feb 2021 01:59
by Karolis316
M42 matuokle ne ilgesne, o trumpesne. Karteris m40, bet variklis tai ne m40. Galva virsuj didesne juk
Todel ir pilama daugiau tepalo.
O jei matuot uzlinkimu, tai neuzlinks ir jei su kokiais 3 litrais vazinesi. Siuo atveju 3 metus ant minimumo vazinejai
Informacija kuria pateikiau grieztai patikrinta su visais kodais, matavimais ir pan
Nemegstu netikslumu, ypac kai dalinami patarimai kitiems, nesamones tik ant savo kailio darau jei jau reikia
Posted: 24 Feb 2021 02:02
by Karolis316
Antanas00 wrote: ↑21 Apr 2012 22:23
1 - Alternator - 25
3 - Not Used
11 - SI Reset - 7
12 - CEL - 8
17 - Not Used
19 - Not Used
20 - ABS - 3
[/quote]
11 - SI Reset - 7
turetu buti:
11 - SI Reset - 19
[/quote]
x20 (e36) 19a jungi ir i 11 ir i 16 ar tik i kazkuri viena is situ dvieju?
Posted: 24 Feb 2021 02:18
by _marshall_
x20 (e36) pin 19 yra oil reset (kitaip sakant pin 7 diagnostikos fyskej. Jis turi but sujungtas su C101 (E30) Pin11. Pin 16 yra airbag diagnostika.
Cia yra ziauriai gera info apie C101
https://www.r3vlimited.com/board/forum/ ... -your-c101
Posted: 24 Feb 2021 04:07
by Karolis316
Reikes persitikrint, kad nebuciau idomybiu padares, ta 16-19 palikau nepajungta, sekdamas senus uzrasus pirmojo iso svapo kur viskas veikia.
Dar ka pastebejau kad fyskej butina ne vien pagal spalvas ziuret, nes du laidai buvo tokie pat nors skirtinguose vietose.
Tik 12 13 laiduku, o niuansu sociai
Posted: 25 Feb 2021 00:45
by Karolis316
11 sujungiau su 19
16 ant dvieju masinu sujungiau su 17, bet kazin ar tai kazka keicia.
Kuriasi
Vnz, atnaujinta teisinga schema:
1 - Alternator - 25
3 - Not Used
11 - SI Reset - 19
12 - CEL - 8
16 - Diagnostic Plug - isvis nejungt arba gal 17?
17 - Not Used
19 - Not Used
20 - ABS - 3
