[All] LSD tepalas
BMW: E30 318is, E36 318is
Re: [All] LSD tepalas
Post by romkasponka » 08 Sep 2008 12:48
Valvoline tai yra tik keli geri variklio tepalai VR1 pusiausintetika 10W60 (importuotoju teigimu nesertefikuota sintetika) ir 10w50 sintetika. Pats naudoju 10W60 jau 3 metus ir galiu pasakyti, kad nuostabios plovimo charakteristikos pas sita tepalą.
Siulau bent biski pasidometi priesh siulant kazka!
SynPower STX Gear Oil
Valvoline SynPower STX Gear Oil is a high performance fully synthetic gear oil specially formulated for superior extreme temperature and service protection. For use in virtually all transmissions and gears of modern cars, trucks and buses where a GL-5 is specified by the manufacturer. Valvoline SynPower STX Gear Oil contains synthetic baseoils to provide excellent protection against wear and corrosion while ensuring compatibility with a variety of seals. Not recommended for Limited Slip axles.
SynPower STX Gear Oil GL-5
Applicable where an API GL-5 gear oil is specified
Available in SAE 75W-90 and 75W-140 viscosity grades
Longer drain intervals
Approved by Scania STO:1 and ZF 05B/07A/12E/17B
Vytis
BMW Fan draugas
BMW: E36-325i
Post by Vytis » 09 Sep 2008 00:13
Kiti pila paprastus transmisojos tepalus arba sena kuris buvo, del pinigu stokos, tai jau geriau toks nei greiciu deziu tepalas, pats sau toki susipyliau ir jokiu problemu nematau.
o apie 10w40 tai tik pasiuliau, galima pirkti koki tik nori, tik reikia kolektyvo,kad kainos butu normalios.
romkasponka wrote:Valvoline tai yra tik keli geri variklio tepalai VR1 pusiausintetika 10W60 (importuotoju teigimu nesertefikuota sintetika) ir 10w50 sintetika. Pats naudoju 10W60 jau 3 metus ir galiu pasakyti, kad nuostabios plovimo charakteristikos pas sita tepalą.
Re: Re:
Post by romkasponka » 10 Sep 2008 12:05
Kada turesit to kas tinka BMW ribotos trinties diferencialams?
pvz ZLS-BMW 75W-140 ?
ernis
Re: Re:
Post by ernis » 11 Sep 2008 15:19
romkasponka wrote:Kada turesit to kas tinka BMW ribotos trinties diferencialams?
Deja i Lietuva sitas geris nevezamas. Tiksliu to priezasciu nezinau, bet tikriausiai del to kad nera pakankamos paklausos butent siam skysciui, o privalomas minimalus uzsakymo kiekis is gamyklos yra arba 4 statines po 209 L arba 40 kibiriuku po 20 L (palete).
Sapnas
BMW: e36 325i coupe megasquirt, e36 325td
Post by Sapnas » 12 Sep 2008 16:55
Pas mus atrodo dar sito yra jei neklystu SHELL Spirax A 85W-140 LS UAB "Valtralita" jei ka y pm
bimmer20
BMW: e39 525tds
Post by bimmer20 » 16 Oct 2008 13:49
kaune zerutij kastrolas 77lt litras
Galutinis terminas yra savaitė po nustatyto termino.
zemelapis
BMW: VW Krokodilas
Post by zemelapis » 29 Oct 2008 20:42
Tai vat pasakykit jus naujokui toki dalyka, nusipirkau as e34 pries kelias dienas, viskas tvarkoj ir pardavejas sake kad yra originali blokiruote. Tai man dabar iskilo toks klausimas, kaip cia ishsiaiskinti ar yra ji ar ne, ant reduktoriaus gal kur parasyta? auto 90m. M50B20
Orsis
BMW: GAZ 51 LS2 6.0
Post by Orsis » 29 Oct 2008 20:47
zemelapis wrote:Tai vat pasakykit jus naujokui toki dalyka, nusipirkau as e34 pries kelias dienas, viskas tvarkoj ir pardavejas sake kad yra originali blokiruote. Tai man dabar iskilo toks klausimas, kaip cia ishsiaiskinti ar yra ji ar ne, ant reduktoriaus gal kur parasyta? auto 90m. M50B20
ant reduktoriaus turetu buti lentele su perdavimo skaiciais bei raidele S, kitas budas http://www.youtube.com/watch?v=Am9Jvj4Bdjw" onclick="window.open(this.href);return false;
proxas
Post by proxas » 29 Oct 2008 22:48
na mashinos nepakelus pagal video nepadarysi - uzhvaryk viena rata ant asfalto kita ant kokio shudino pavirshiaus ir duok shniurais - jeigu kasis abu ratai - visks oke ;)
zhinoma ramiai vazhiuojant posukyje neturi girdetis trankymu per vazhiuokle, jeigu girdisi - tai reduktorius virintas ;)
Arciss
Post by Arciss » 02 Nov 2008 21:23
o ka manot apie REPSOL cartago 75w90? gan nebrangus, kas bandet, ka galetumet pasakyt apie ji?
BMW e30 318is ex
BMW e30 325 24v ex
BMW e36 325 ex
rce
BMW: barzdacar
Post by rce » 24 Nov 2008 13:50
LSD tepalas yra 75/140 toki turi tik kastrolis. jis gamina bmw o ne opeliui ar nisanui. i nisana gali pilti kaika kita nen blokiruote kitokia. paskui nagu negriauskit kai nusuks blokiruote...
-VELDET- BMW karalyste
zemelapis
BMW: VW Krokodilas
Post by zemelapis » 24 Nov 2008 14:15
Nu va cia tu klysti, tas liqui moly kur ziurejau irgi gamina specialiai bmw! taip kad ne tik castrolis gamina ...
"Vollsynthetisches Hypoid Getriebeol LS SAE 75W-140 (GL5) Leidimai: API GL-5, BMW Hinterachsgetriebeoil, Scania STO 1:0, VME, ZF TE-ML 05D, 12D. "
rce
BMW: barzdacar
Post by rce » 24 Nov 2008 14:22
bmw lsd yra bmw lsd o ne taivanis...
pilt reikia tas kas priklauso o ne tai ka galima gauti papigiai...
Post by EXvaldelis » 04 Dec 2008 02:59
LaimisBMW wrote:Visi zinom kad pilasi 75W140 (pvz Castrol Saf-XJ), bet kaina uzkilusi castroliu belekokia, 100 lt uz bonkute beveik. Gal yra pigesniu variantu ? Andriuxa buvo minejes kad galima pylti sintetini greiciu deziu tepala, tai cia nelabai supratau apie ATF kalbama ? Ar apie 75W90 ?
Airijoje sis tepalas 18-20 euru 1 L.kalbu apie Castrol SAF-XJ.Tik kazkodel kai klausem BMW centre koks eina i M3 E36,tai ismete modelius kuriem pilasi tas tepalas,tai ten tik Mpoweriai buvo surasyti.Gal juose tik diskelines LSD eina,o variantu tepalo tai gal 10 skirtingu kompaniju isvardinta.Nes tas tepalas tai kaip ir automatiniu deziu sintetinis tepalas,ir veikimas principe tas pats.O kai paklausiau E36 328 tai tas(suknistas lenkas) net kompe neziurejo ir ranka israse kad tas pats ,tik tada dar nezinojau,kad man nurode ta pati,kur ir Mkei.Tai uz poros savaiciu uzlinko,tik turbut ne tepale beda buvo,nes kai keiciau tepala,labai jau nesvarus isbego.Po laiko kaip sakant pakeistas tepalas.Ir 40 euru i bala.
Post by romkasponka » 08 Jan 2009 18:07
Tomoox wrote:tai kas 10k ir keist kaip varikliui? :D nors ir nezinau bet abejoju kad taip daznai reiktu keist.
priklausomai nuo to kaip eksploatuosi, nes gali ir to neuztekti. Pas M3 DTM isvis siurblys su radiatorium stovejo, turbut ne del grozio. O tepalo gyvavimo laikas gana smarkiai nuo temperaturos priklauso...
proxas
Post by proxas » 26 Jan 2009 16:20
OZas wrote:DEMESIO YRA GALIMYBE GAUTI SIA SAVAITE TOTALIO TEPALO 75/140 LSD DIFAM KAINA JO BUTU LITRAS 30 LT 863185531 KAUNAS
Imu 2 litrus, jeigu prazhiopsosiu uzhpirkima perspekit numeriu 8 674 18857 - ta pacia diena prileksiu atsiimt.
Tomoox
Post by Tomoox » 05 Mar 2009 15:22
http://www.avatra.lt/index.php?action=k ... eke&id=175" onclick="window.open(this.href);return false;
Post by zygasbmw » 05 Mar 2009 19:46
nu ir ka tu tuom norejai pasakyti,kad imetei nuoruoda su paprasta sintetine alyva,kuri net netinka LSD. :vis
zemelapis
BMW: VW Krokodilas
Post by zemelapis » 05 Mar 2009 20:16
Taigi parasyta apacioj + LS kodel netinka? Be to abejoju kad paprasta alyva kainuotu 50lt/l
Post by zygasbmw » 05 Mar 2009 20:29
abejoji kad sintetine alyva paprasta gali kainuoti 50lt uz1litra.tai nueik i parduotuves ir pasiziurek. :D aisku yra ir kur po 20lt bet ten isvis totalus S. o kad prie specifikaciju parasyta LS tai tikrai nereiksia kad tinka blokiruotems.ir ypac diskelinems.
