[E91] 320d flashing alpina D3 software
Sveiki, susiduriau su http://www.bmwcoding.com/showthread.php ... 3-software čia paminėta problema, kaip butu galima flashint orginalu softa..
Hello, i have E91 2006.06 320D Automatic transmission and i tryed to flash Alpina D3 using this thread info http://www.e90post.com/forums/showthread.php?t=709020, used D+KCAN cable with WinKFP, by these steps:
"in WINKFPt this software is marked as 7811921 under DDE604. You go to Comfort mode, click on Choose ZUSB and find 7811921 somewhere in DDE604 .. Then OK, enter VIN and DONE. Then click on Program and it should start flash. I used classic OBD K-Line cable and I haven't used any battery charger since the flash is not longer than 15 minutes." flashing was ok, and after flash i got transmission error, dsc error and so on...
also tryed: "Warning: If you dont have the Spdaten 48.1 or 49.3 updated correctly into Ediabas and NCSexpert, after doing this coding the car will be Dead and show a gear warning on cluster but this can be fixed by correctly updating the NCSexpert...
Here is what you do:
0-Start ignition with cluster lights on
1-Load NCSexpert
2-File Use EXPERTMODE profile and click ok
3-(F1) Vin/ZCS/FA
4-(F3) SG ausw
5-Choose E89 chassis click ok
6-Choose CAS click ok
7-(F6) Back
8-(F4) Read ECU and pick EGS module click ok
9-Press F3 (execute JOB)
10-After it says coding ended your done!
11-Close out NCSexpert"
Coded was fine also, but nothing changed, still transmission error and it says that it is defective, also i cant start my car anymore.. also tryed to clean errors with INPA same problem.
The tools i used http://www.e90post.com/forums/showthread.php?t=1220039..
Don't know what to do... how to flash stock back again...
Re: [E91] 320d flashing alpina D3 software
Galbut su CAS moduliu problemos ?
kaip tai reiketu ispresti ?
