[e46] m47d20 100kw 2001m CAN communication
Diesel (M47D20 - 204D1 - DDE 3.0 - MT/AT)
DTC Description
42 - DDE control module (EEPROM and configuration)
72 - CAN: Communication ASR - EGS
45 - Injection pump: CAN malfunction
Brake (ABS/ASC/DSC - Diagnose)
DTC Description
92 - CAN Communication Bus Fault - Receive Error
- Present
95 - Can connection to DDM/DDE
- Intermittent
Instrument (Instrument (Instrument cluster ) - Diagnose)
DTC Description
F4 - CAN: No ID
Climate (Climate control - IHKA/IHKR (IHKA/IHKR: Climate control))
DTC Description
1C - AUC sensor, open circuit
- Intermittent
1E - AUC heating, short circuit to negative
- Intermittent
Gearbox (EGS (Automatic transmission) - Diagnose)
DTC Description
83 - CAN: communication instrument
82 - CAN: time out ASC
Immobiliser (Immobiliser - EWS3 (Electronic drive-away protection 3))
DTC Description
No fault codes
Restraints (Airbag - Diagnose)
DTC Description
No fault codes
Multifunction (Central Body - PDC (Parking assistance system))
DTC Description
12 - Distance sensor, rear center left
- Signal, open circuit
- Permanent
Fault frequency 50
Multifunction (Central Body - ZKE (Central body electronics))
DTC Description
No fault codes
Multifunction (Lights center - LSZ (Lamp switching center))
DTC Description
No fault codes
ant skydelio dar temp rodykle uzsilenkia iki galo,apsuku nerodo,greicio nerodo,dezes klaida rodo. tai atsiranda tai dingtsa sita beda. kame cia beda,yra minciu ?
DTC Description
DTC Description
- Present
- Intermittent
DTC Description
F4 - CAN: No ID
DTC Description
- Intermittent
- Intermittent
DTC Description
DTC Description
No fault codes
DTC Description
No fault codes
DTC Description
- Permanent
Fault frequency 50
DTC Description
No fault codes
DTC Description
No fault codes
