[E38] NEDEGA GALINIO BEGIO SVIESOS
E38 95m automatas 3L, ijungiant galine pavara [R] nedega galines sviesos, pirkau jau su sita problema.
Gal pas ka yra buve patarkit ka darit, is pradziu nuo menknekiu gal !? (saugiklei, lemputes tvarkoi!)
Re: [E38] NEDEGA GALINIO BEGIO SVIESOS
atbulinio begio varlyte numirus prie dezes.
Reverse lights switch?
zmones !!! cia automatas !!,kur ta jusu varlyte atbulinio begio
hebra kaip zinau varlites tos ant automato nera, varlite tik ant mehanikos man sake.
Dar pastebejau toki dalika kad ijunkdamas bet koki begi pvz: [D] arba [P] nesvarbu ta raide nedega ekrane, taip pat nedega raides A-S gal cia pre sito pacio ar nea ?
If PRND 432 is not showing on the instrument cluster...it's not a bulb issue...it is an electronic issue with the components that determine what gear the car is in.
I believe there is a component on the transmission housing...and also check the gear select lever...there's a cable that goes between these two areas that tell the IKE (instr cluster) what gear the car is in. The IKE then tells the LKM (lamp contorl module) to turn the reverse lights on. So again, the electrical components that tell the cluster & LCM that the car is in reverse has failed to communicate this data.
tankas please say Lithuanian or Russian. I understand you. thnx
Ten ne mano mintys, del to kaip citata imeciau. Jei su Anglu nedraugauji, gausi paprasyti kad kas isverstuGangPum wrote:tankas please say Lithuanian or Russian. I understand you. thnx
per google translate isverciau tai nu nafik
gal kokia relei amen atejo, kur jas rast? ir kaip suprast kad parejo ?
nera jokiu reliu,is automato kompo per BUS i skydeli,is jo i sviesu bloka , is sviesu bloko i lempas
