[E38] NEDEGA GALINIO BEGIO SVIESOS
GangPum
BMW: E46 330ci
Post by GangPum » 21 Oct 2012 22:58
E38 95m automatas 3L, ijungiant galine pavara [R] nedega galines sviesos, pirkau jau su sita problema.
Gal pas ka yra buve patarkit ka darit, is pradziu nuo menknekiu gal !? (saugiklei, lemputes tvarkoi!)
Justukas
BMW: e30 e36/5
Re: [E38] NEDEGA GALINIO BEGIO SVIESOS
Post by Justukas » 21 Oct 2012 23:13
atbulinio begio varlyte numirus prie dezes.
tankas
Post by tankas » 21 Oct 2012 23:14
Reverse lights switch?
Post by EXvaldelis » 22 Oct 2012 01:10
zmones !!! cia automatas !!,kur ta jusu varlyte atbulinio begio :D
GangPum
BMW: E46 330ci
Post by GangPum » 22 Oct 2012 10:15
hebra kaip zinau varlites tos ant automato nera, varlite tik ant mehanikos man sake.
Dar pastebejau toki dalika kad ijunkdamas bet koki begi pvz: [D] arba [P] nesvarbu ta raide nedega ekrane, taip pat nedega raides A-S :) gal cia pre sito pacio ar nea ?
tankas
Post by tankas » 22 Oct 2012 13:16
If PRND 432 is not showing on the instrument cluster...it's not a bulb issue...it is an electronic issue with the components that determine what gear the car is in.
I believe there is a component on the transmission housing...and also check the gear select lever...there's a cable that goes between these two areas that tell the IKE (instr cluster) what gear the car is in. The IKE then tells the LKM (lamp contorl module) to turn the reverse lights on. So again, the electrical components that tell the cluster & LCM that the car is in reverse has failed to communicate this data.
GangPum
BMW: E46 330ci
Post by GangPum » 22 Oct 2012 20:28
tankas please say Lithuanian or Russian. I understand you. thnx
tankas
Post by tankas » 22 Oct 2012 21:39
GangPum wrote:tankas please say Lithuanian or Russian. I understand you. thnx
Ten ne mano mintys, del to kaip citata imeciau. Jei su Anglu nedraugauji, gausi paprasyti kad kas isverstu ;)
GangPum
BMW: E46 330ci
Post by GangPum » 22 Oct 2012 22:19
per google translate isverciau tai nu nafik :D
gal kokia relei amen atejo, kur jas rast? ir kaip suprast kad parejo ? :)
simaxsas
BMW: E36 318+bezdalai
Post by simaxsas » 23 Oct 2012 19:17
nera jokiu reliu,is automato kompo per BUS i skydeli,is jo i sviesu bloka , is sviesu bloko i lempas
