[e39] webasta
- BMW: e39 530d 142kw
[e39] webasta
Norejau paklausti kaip pas mane ijungti webasta? Pas mane programuojama su dwiem timeriais. Bet cia tas aux ventilation kiek skaiciau tai salono ausinimas, o ne webasta kad pasildytu ziema.. Beje kiek suprantu kol nera zemiau -5laipsniu as jos nepatikrinsiu, nes aukstesnej temperaturoj ji paprasciausiai nesudirba, taip? Buciau dekingas uz kuo platesne informacija del webastos, nes anksciau turetose masinose pas mane jos nebudawo ir nesu su tuom susidures. Tai tiek
http://postimage.org/image/jhzangt1l/
Re: [e39] webasta
jei yra webasto rikia su kompu perprogramuoti i aux heater'i
Re: [e39] webasta
Ir kai perprogramuos ant aux heater'io tada su taimeriu tipo nustatau ziema 6:45, nes 7wal waziuoju i darba, tai atejus i masina jinai bus pasildyta ar kaip? pasildo warikli ar ir salona? yra du taimeriai kam antras? tipo du laikmacius nusistatyti galima ar antrasis yra kada isjungti webasta nustatymui?
Re: [e39] webasta
Cia ne visai i tavo klausima atsako, bendra info kaip veikia Webasto ant E39'tu:
As you are aware, the BMW 5 Series Diesel is fitted with the Webasto Thermo Top C fuel-burning heater as standard, which is used as a supplementary heater. In this application, the Webasto heater only operates when the engine is running and the outside temperature is below 5°C. In conjunction with BMW GB, we have developed a simple upgrade, which includes the addition of a simple electrical interface harness, which will switch the heater on independently.
(If you have MID there is a standard timer program feature you can set up..but you may or may not have the remote aswell... Ose1665) (This upgrade remote is for us low OBC guys... and I assume MID's without a remote Ose1665)
The parked car heater is started by a remote control device and warms the coolant independently from the vehicle's engine. The vehicle's blower system takes the warm air into the cabin and, at the same time, pre-heats the engine.
Once this upgrade has been installed, it will provide pre-heating for your vehicle prior to commencing your journey.
Some of the benefits associated with such a system are as follows:
· Warmth and comfort of a pre-heated interior - a centrally heated interior.
· Screen defrost and demist - increase safety with a safer clearer vision through the windscreen at the start of your journey.
· Pre-heated engine - no more cold starts/easier starting.
· A pre-warmed engine - a better engine response from cold.
· Reduced engine wear
· Reduced engine emissions - lower emissions from a preheated engine.
· "Just drive off straight away and enjoy your journey."
The standard installation includes full system integration with the parking heater controlled by a Telestart Remote Control. This allows switching on and off of the system by a remote control handset with a range of 600 metres.
In the UK, this accessory is exclusively offered by official BMW Dealerships under the following BMW Part Number: 95.06.0.000.008 or 95.06.0.000.009 (dependent upon model year), therefore you should contact your local BMW Dealer, quoting either of these part numbers in order to obtain the full technical and product support expected within the BMW programme.
Re: [e39] webasta
pasmane panasi beda nzn kada jis pasileis webasto nors pasmane jis stovi maciau as ji pasmane mage kasetine bussine bmw tai ten nera nustatymu kiek zinau sawaime turetu jis pasileisti bet kai nebuvo lauko temperaturos daviklio rode -40 bet vistiek nepasileisdavo gal saugikliu truksta nes saugikliu tai tikrai mazoka stovi paliginus su tokia komplektacija
Re: [e39] webasta
sveiki, gal kas zinote kas gali perprogramuoti bmw e39 530d webasta Kaune arba Kedainiuose. Nes pas mane ji uzsikuria tada kai uzvedu auto. Buciau dekingas uz info.
Re: [e39] webasta
tai taip ir veikia ji prie tokiu temperaturu, ko tu nori, kad isvis neisijungtu?
Re: [e39] webasta
galiu kaunezymetojas wrote:sveiki, gal kas zinote kas gali perprogramuoti bmw e39 530d webasta Kaune arba Kedainiuose. Nes pas mane ji uzsikuria tada kai uzvedu auto. Buciau dekingas uz info.
http://www.carelectric.lt
Re: [e39] webasta
as noriu ja perprogramuoti, kad galeciau ja valdyti per BC, kad pasikurtu uzstacius tam tikra laika. perprogramuoti kompa i aux, aisku jei tai imanoma.
Re: [e39] webasta
Sveiki,
Norejau jusu pasiteirauti del vieno dalyko.
Esu susiprogramaves webasto, kad butu su timeri'u. Ant teliko galima nustatyti tik aux. heating laikus, o dabar vasara reiktu aux. ventilation. Tai reikia vel persiprogramuoti, ar galima kazkaip kitaip padaryti, kad auto suprastu, kad reikia vedinti, o ne sildyti?
Ir, kaip suprantu aux ventilation ima ora is lauko ir pucia i masina?
Bet dabar kai lauke karstas oras, tai jokio reikalo ijungti ventilation, nes vistiek karsta ora pus?
Ar galima padaryti, kad pustu salta ora(kad kondicionierius isijungtu) ?
Gal jums, kaip ismanantiems juokingai nuskambejo toks pageidavimas, bet as kaip nelabai zinantis ir per google, neradau informacijos, tai uzklausiau pas jus. Renkasi cia gi nusimananciu zmoniu, labai pagelbetumet, jei pasakytumet kaip cia kas
Re: [e39] webasta
Jonavoj galiu suprogramuot webasta nuo laikmacio.
Autodiagnostika,programavimas,kodavimas,el dalies remontas.
www.autodiagnostika-jonava.com
+37060707640
+37060707640
