Alytus
Re: Alytus
dar nespejau idet, neseniai tik parsiveziau.KarolisBMW wrote:dar paklausiu o kokia jis paskirty atlieka? suverzia viska? kaskas apciuopiamo po uzdejimo jauciama?
paskirtis, tai panasiai kaip rasporkes, sustiprina kebula ir posukiuose turetu maziau kebulas krypti.
In this pic, the green outline is basically the cross member that ties the running gear together and is secured to the chassis at the two points indicated by the orange arrows. The engine also secures to this (the big rubber mounting), which probably helps rigidity, but given that it is all rubber mount-based there is room for movement. Siginificantly, there is little to constrain the forces acting on this member from side to side (as indicated by the blue arrows), which are the ones that take effect during cornerning. Subsequently I have found this to be the most beneficial "tightening-up" mode for the front end.
Calypsorot | '91 | 320i | M-technic
- BMW: 328
Re: Alytus
Maniskio kaledu senelis ateis tik po triju karaliu, dovana skirta bus visiskas vaziuokles isrinkimas poto surinkimas su idomesnemis detalemis sarnyrais ir etc. Senis saltis planuoja uzsibuti mazdaug tris menesius
Re: Alytus
vienai coilai, kitai 13 knopkiu full obc best christmas ever!
Driving
:: 91' e30 325i m50 Cabrio ::
:: 04' e46 m3 Cabrio ::
Driving
Re: Alytus
dio wrote:dar nespejau idet, neseniai tik parsiveziau.KarolisBMW wrote:dar paklausiu o kokia jis paskirty atlieka? suverzia viska? kaskas apciuopiamo po uzdejimo jauciama?
nu pas DIO buvo pasikreipes kebulas ant posukio gardino g. tikekimes su sutu navarotu nesikreips
Re: Alytus
susuks sita kebula, stogu zemyn (grumo tevas)Irmukas wrote:nu pas DIO buvo pasikreipes kebulas ant posukio gardino g. tikekimes su sutu navarotu nesikreips
Re: Alytus
Sveiki nuciupau sy vakara R18 styling 37 dar gerai neapziurejas ir pilnai neyvertines ju stovio parduodu nes nenoriu R18 noriu R17 Tad jei ka sudomino kolkas skelbimas cia http://forumai.bmw-klubas.lt/viewtopic. ... 1&t=105966
- Mantas[E38]
- BMW: E38 740i
Re: Alytus
kaip suprast ?:DDD kazko neikirtau arba kazka praleidaudio wrote:susuks sita kebula, stogu zemyn (grumo tevas)Irmukas wrote:nu pas DIO buvo pasikreipes kebulas ant posukio gardino g. tikekimes su sutu navarotu nesikreips
Maniskis gavo 16:9 monitoriu su DSP garso sistema, siutus oda altorius bardaciokus ir galines apsifkes.
- BMW: 328
Re: Alytus
Sveiki, gal kas kartais turit parduoti r13 175/70 padangas ziemines DYGLIUOTAS?
Re: Alytus
BEJA, del bendro supratimo - valks vagena corado yra gaidys
Driving
Driving
Re: Alytus
Taip visa laik ir buvo
Re: Alytus
BEJA, del bendro supratimo - bmw siaurastopis better than placiastopis
Re: Alytus
BEJA, u wish..
Driving
Driving
Re: Alytus
Arthur wrote:BEJA, del bendro supratimo - bmw siaurastopis better than placiastopis
Driving
Driving
- Mantas[E38]
- BMW: E38 740i
Re: Alytus
dėja..
Re: Alytus
Re: Alytus
Kas čia su chuliganu siaučia vakarais Alytuje?
Re: Alytus
Su surudijusiu kapotu?
Driving
Driving
- Mantas[E38]
- BMW: E38 740i
Re: Alytus
:DDDdio wrote:Arthur wrote:BEJA, del bendro supratimo - bmw siaurastopis better than placiastopis
Re: Alytus
BEJA, del bendro supratimo, FANATIC'ui ir Dio is kazkur prisipaise sitam reikale
Re: Alytus
kokie BMW!!!! kokie Caradai!!!!! **. GONDA is BEST!!
