Šiauliai
Moderators: unguriux, KLP325
Marcius325td
BMW: E30 325coupe;E36 325i
Re: Šiauliai
Post by Marcius325td » Sun Jan 20, 2013 12:26 pm
Jei i zoknius tada prileksiu tiesej ten
Egass
Re: Šiauliai
Post by Egass » Tue Jan 22, 2013 2:52 pm
Brutal Money Waster
vks
BMW: e36 compact
Re: Šiauliai
Post by vks » Wed Jan 23, 2013 11:00 am
kam reikia salono odinio compact
murfiis
BMW: e34
Re: Šiauliai
Post by murfiis » Wed Jan 23, 2013 11:14 am
Gal kas ardet ir turit m30b30 ar m30b35 karomyslu kreipianciasias? o gal galit pasiulyt kokia alternatyva?
golden_qpe
BMW: X5 V8
Re: Šiauliai
Post by golden_qpe » Wed Jan 23, 2013 12:02 pm
vks wrote:kam reikia salono odinio compact
jau sikana nusalei anee :D
vks
BMW: e36 compact
Re: Šiauliai
Post by vks » Wed Jan 23, 2013 1:06 pm
nea senai jau garaze stovi
vks
BMW: e36 compact
Re: Šiauliai
Post by vks » Thu Jan 24, 2013 12:24 pm
kas turit suba ir stipreka uz nebrangiai?
vks
BMW: e36 compact
Re: Šiauliai
Post by vks » Thu Jan 24, 2013 2:51 pm
ar cia gyvu yra :mad
tomsas22
BMW: E46 2,2iT; 2xE30; E34 M5 3,6L; E30 325iC
Re: Šiauliai
Post by tomsas22 » Fri Jan 25, 2013 1:15 am
nevisada bet yra :) :alc
gudrutis
BMW: E36 M47
Re: Šiauliai
Post by gudrutis » Sat Jan 26, 2013 2:44 pm
kas rytoi dalyvaujat baciunuose?
e39
BMW: e39 saloon
Re: Šiauliai
Post by e39 » Wed Jan 30, 2013 3:29 pm
Sveiki gal kas rekomenduotu gera meistra kuris padarytu diagnostika e39?
tomsas22
Re: Šiauliai
Post by tomsas22 » Thu Jan 31, 2013 5:20 pm
arba simaxas arba as, pasirinkimo teise. patarciasu simaxa, nes as tik kita savaite galiu primti :D
golden_qpe
BMW: X5 V8
Re: Šiauliai
Post by golden_qpe » Fri Feb 01, 2013 8:28 am
e39 wrote:Sveiki gal kas rekomenduotu gera meistra kuris padarytu diagnostika e39?
Cia tavo e39 avatare? sakyk kas yra,be diagnostikos pasakysiu :D
BEMSAS
BMW: E46 fl
Re: Šiauliai
Post by BEMSAS » Fri Feb 01, 2013 9:10 am
ka jau ka bet goldens sita pitaka zino kaip nulupta :D jei cia tapati masina kur avatare
Mielsonas
golden_qpe
BMW: X5 V8
Re: Šiauliai
Post by golden_qpe » Fri Feb 01, 2013 10:51 am
per 3 metus eksplotacijos suaidraugauji lyg su desine ranka paauglystej :D D bemsas jau susidraugaves su savo ,kaip su abejom :D
BEMSAS
BMW: E46 fl
Re: Šiauliai
Post by BEMSAS » Fri Feb 01, 2013 11:41 am
:D :D :D
Mielsonas
e39
BMW: e39 saloon
Re: Šiauliai
Post by e39 » Fri Feb 01, 2013 12:25 pm
Sveikas taip mano:) taigi nezinau pradejo nebedirbti nei ant benzino nei ant duju, nuvarius padaryti diagnostika ( ale ) pasake kad zondas vienas neveikia tai teko pakeisti abu ir vistiek tas pats:) pakeiciau zvakes,babinas,pypkes ir rezultato nera:) is kamino uodziasi nesudeges kuras traukos nera kaip turi buti:( todel ir reikalynga gera diagnostika nebent tau yra buve jau:)
simaxsas
BMW: E36 318+bezdalai
Re: Šiauliai
Post by simaxsas » Fri Feb 01, 2013 8:22 pm
kompresija pasimatuok :bot,gal gelezi problemos
golden_qpe
BMW: X5 V8
Re: Šiauliai
Post by golden_qpe » Sat Feb 02, 2013 11:30 am
zvakes buvau sudejas naujas praita vasara berods,galejai ir nekeist,reduktorius man buvo parejas ir atjunginedavo dujas uzmynus nuo 3k rpm,bet jy perrinko ar pakeite kiek zinau po manes ja jau turejas zmogus,siaip man vaziuodavo jinai be didesniu issikalinejimu,tik kad kebulas pavargo,plius dar buvus is svedu parvaryta,radijatorius naujas idetas uzpraita vasara,vandens pompa irgi,dar berods termostatas.....slenksciai nudauzyti nukritus nuo dankrato,desinys prie galo nukentejas nuo bortuko,galines dureles nubreztos nuo garazo vartu,bamperis pakrites ir kapotas nuskriausti nuo buksyravimo sniuro,bagazines vidus iskirmijas nuo vandens kuris begdavo per taivanio lempas
`PrX_
Re: Šiauliai
Post by `PrX_ » Sat Feb 02, 2013 12:30 pm
Gal kas turit m20b25 generatoriu gyvą? arba pasakysit kame reples kodėl važiuojant mirksi krovimo, rankinio ir abs lemputės? :D
Bmw e46 Touring
